dvb250
Alright guys i really need help here - 2002 Ford F350 - There's a growling noise while in 4x4 from the drivers side front.
It does not make the noise when the hubs are locked and the truck is in 2x4
It does not make the noise when cruising (maintaining speed) Only when you are under acceleration or deceleration.
WHAT I'VE DONE
I've replaced the drivers side front bearing in the spindle - The wheel bearing has no play and it's not binding - The drivers side front wheel joint was good when i replaced the bearing in the spindle.
I pulled off the front diff cover and found no signs of damage or wear - Changed the fluid and moved on
Removed the transfer case and replaced all the bearings and the drive chain.
I sent out the front drive shaft and had it re-built and balanced
Obviously this is getting expensive and I can't keep throwing parts at it - Someone PLEASE HELP
WHAT I'VE DONE
