06 will crank but not start
RandyH
Western Colorado
Here's an Internet pic of the IPR valve itself and what it looks like under the turbo on mine. Hope that helps.
RandyH
Western Colorado
There is not a 3/4" nut for the solenoid that I'm aware of on the 6.0l. Is your truck a 7.3l? I believe it has the 3/4" nut you mentioned. Will take a quick look.
Whitworth
Yazoo City, MS
That explains a lot I've been looking up 6.0 but everything would talk about this bolt and I couldn't figure that out!
am
mine is a 6.0L that's what had me so confused so what's a good link to show me how to do what I need to do now?
RandyH
Western Colorado
I'm certainly no expert but you may need to step back a minute and regroup. There are some troubleshooting tips around the Internet for no start conditions. Before you spend a lot of energy chasing things, you should do what Dave mentioned and check for any codes. You could do this yourself with an inexpensive OBDII code reader or find someone you know that has one. That will help you narrow down where to focus your energy. The 6.0l has to meet certain conditions like sufficient oil pressure, etc. to allow a start. It could even be something like low FICM voltage completely unrelated to the HPOP/ICP/IPR part of the system. With some codes the members here can help get you there quicker. Good general info links below.
http://www.thedieselstop.com/forums/f23/troubleshooting-no-start-condition-252803/
http://www.knowyourparts.com/technical-articles/diesel-start-diagnosis/
Whitworth
Yazoo City, MS
Randy thank you so much that is extremely helpful in every kind of way! I have almost tried all of that. I have test the IPR which turns out it is bad. It's stuck in the open position. Not saying this is going to be my fix but I have one on order and will be here tomorrow. Fingers crossed this will get my truck back on the road. I appreciate all your help as I try to wade my way through this new challenge in our lives with my husband here to teach me! Forever greatful!
Whitworth
Yazoo City, MS
Will do! May be toward the end of week bc gotta replace the hydraulic hose on my bucket truck tomorrow & find the leak before the weekend! But will definitely post why happens when I put the new IPR in!
No problem, hope it gets you going again. Let us know how it works out.
Whitworth
Yazoo City, MS
Well believe it or not I did it!! Took IPR out and it was bad put new one in and it worked! Thank you all so much for providing such helpful information! Couldn't have done it without yall!
rhensonsr
