F350 Hubs
BobA
VA
I have a 2002 F350 Super Duty Dually. I need to change the hubs. Will Mile Marker 449SS hubs, if I use the conversion kit work on this truck?
BobA
VA
According to the manufactures site (http://milemarker.com/hubappguide/) they will work on your F-350. Check it out for yourself. :)
There are actually several different hubs that will work on a F350 Super Duty if it is single rear wheel, but the being a dual rear wheel makes a difference. I am just trying to find out with the conversion if it will work on a dually. I had already read the app guide but it doesn't clarify. I will call them tomorrow, I was just trying to save some time on ordering.
I have a friend who has a 2000 F-350 Dually. His hubs are the same as mine (2004 F-350 not dually). There is an adapter for the ten hole wheels but nothing for the hubs.
cpadolf3
US
I am running the MileMarker 449SS hubs on my F250 and LOVE them. I originally had the auto locking ones, and they were nothing but trouble. The price of one was more than the price for both of the 449SS's. If you have the Dana front straight axle they should be the same (even though it's F250 vs F350). Definitely go that route regardless. Much better hub. I will say though, put removable loctite on the hub bolts. 800 miles after the conversion and I heard this clicking. Turned out to be the hub flopping around inside the axle. Lost two of the Allen bolts out of each side.
Sent from my SM-N910V using Tapatalk
