Aerated Oil!
roosterdiesel
Earl needs B100
Amarillo,TX
Saturday night when merging on to the interstate engine stumbled at around 2400 rpms and 3/4ths throttle....hit it again and see LPO and HPO gauges dancing.:rant
Made a few calls, got home and checked the oil...it was aerated. Changed it yesterday and it's aerated on crank up.
Looks like I have a cracked pick up tube for the LPOP. Its now so bad that HPOP gauge is wavering and I have speed surge.
Only way to do it right it to yank the engine. :rant Least it will be going back together with a girdle, forged rods cryoed, head studs and valve springs.:sly
DIY hybrids??:innocent
Wow Earl.
Sure will be a good opportunity to make some improvements.
I guess it would be stupid to ask if you're gonna do the work yourself? :D
roosterdiesel
Earl needs B100
Amarillo,TX
Yes I'll do the work myself. I'm even going to build my own injectors and flow test them in our Memphis, TN store.
I'm looking for a 450-475hp range. Much over that and I'll have to get a clutch.
platinum01
Willis, TX
Sorry to hear about the problems but at least it will be a nice turn around for you. Let us know how the DIY injectors work or how hard the process it. Just curious.
Tbar
SDD STAFF/Moderator
You don't have coolant seeping in do you???
Tbar
