Question '97 PSD MPG's
diesel patriot
ofallon,mo
His current tire size is only one size larger than factory. It probably increased his mpg numbers a little. I do know he drives sensible (coasts hills, steady take offs, etc...) I was still wondering if there is a programmer out here that would help with a few more mpg's? I figured someone has probably tried one. I know his #'s are good but just want to see if they can get better.
DA-HEAT
The First Stroker
Chaffee, MO
I tried everything to increase my mileage and nothing seemed to help. I added 3" downpipe, 4inch exhaust, good air filtration system, and a T. Wildman chip with an economy tune which was suppose to work great. The only difference is the amazing amounts of power I have gotten:sly Before bonestock the truck averaged 17-17.5, now after all the mods and on economy tune I average 18, I don't think that is too bad considering it is a 4 door dually with zf5 and 4.10 gears, but if only for fuel economy save the money and just drive easy as possible.
Paul H
Thronville, Ohio
95- 97 PDS has a fuel mile sweet spot at about 2000 RPM
My old 96 with tymar intake and 5" stacks with a custom Tony Wildman burn for HP gets on average 17 to 18 MPG except winter fuel
tubzz
st.clair mo.
I know that you can get a check engine light if the cap is not on all the way on a gasser. On the newer cars and trucks dont know about the PSD.
not on OBS trucks,they are not that smart.all they know to do is go with what ever is behind them
the best i have got out of mine was 19.5 last fall coming back from a race done in arkanasa. i get 15-18 around here depending on who fells lucky and get 10 - 13 with the camper depending on head wind.
but if he is getting 21-22 out of it i wouldn't do anything to it.just keep up the good work on a good running truck;tu
Romie64
