comment The "chips" are down
MPG numbers hold.
have confirmed first discovery, the best way to drive it for MPG is to keep the smoke IN the tailpipe.
confirmed Piece of Advise #2, "When someone borrows your truck, flip the chip into "stock" then put the selector switch in your pocket"
roosterdiesel
Earl needs B100
Amarillo,TX
Stay AWAY from the econo tunes when towing! They generally run more timing to increase mileage.
Glad you got some mileage back JL!
figured that out pretty quick.. you can hear the difference in the engine's overall noise level just driving in tow vs econo
best part about it is, I can go get 10,000 lbs of hay and not have to sit down with a map and a highlighter and plan my route.
best, best part about it, is going another 100+ miles on a tank of fuel
