Fd-4604?? Fd-4609??
dsonyay
Slidell, LA
Patrick-- I want to add that you should copy the fuel filter change instructions and post on the DIY section. I looked there earlier and didn't see anything.
David
ponyexpress94
Diesel Power Junkie
Maryland
Very nice write-up on changing the filters! I can't wait to get started. I'm so glad I won't have to remove the fuel lines. When I saw the plastic connectors attached to the end of the fuel lines, I thought, Oh geez, something I'll break in the name of routine maintenance. :)
Patrick-- on a side note, every couple of weeks I drain some of the fuel from the HFCM. Should I drain all of it, or just about 30 seconds worth like the manual suggests.
David
David,
30 seconds to a minute is sufficient in most cases and that is what I usually do too. You can go longer but after a point you are just pouring out good fuel, because a truck that fills up with good fuel regularly and is driven often won't collect a lot of water. I've never had a bad batch of fuel to actually see an obvious change in the diesel being drained to know how much water there was and when you have drained it all. I don't think you can completely drain the filter housing when the system is closed because I think you would be siphoning fuel out of the tank through the fuel lines. Nice truck by the way, I really like flat beds because I love hauling stuff!!!
I'll see what I can do about getting the write up posted for others to use, thanks for the compliment and suggestion.
Keep on truckin' :sweet
snicklas
Super Moderator
Staff member
Greenfield, Indiana
Seeing the HFCM filters are the same, are the housings the same. I would like to replace the drain plug my 6.0 HFCM with the fitting it sounds like are on the newer ones. Is this possible?
2x6 bulldog
Buford/GA
FD 4609 is the Motorcraft part number for both the fuel filters for the '08 6.4 liter diesel.
