Grill Removal
platinum01
Willis, TX
Didn't really know were to put this at. I figured since it was a grill from a 6.0 this would be the best place. I did an 05 upgrade on my 01 and before I installed the grill I painted the honeycomb insert to match the truck. Well I guess there were some area that I didn't sand very well and the paint is starting to peel off.
Now I need to paint the insert before the big race in Oct. So how do you remove the grill. I know on the 99-03 the clips are right there, well now there is a lip that the clips sit behind so I can't push them in to remove the grill.
Thanks for the helps guys.
strokepower
Stroke=Power
Cook Station, Mo
its definitely not as easy on the 05+ trucks... this is what i do... i take the 4 screws on top out.. then get a long screw driver (12" or so)... and bend the grill back just enough to get that screwdriver down to the clips.. i push on the clips with the screwdriver (you'll see the lip you need to get between... then ones the screwdriver is where it needs to be i just turn it a half turn to seperate the clip from the base..
it'll make more sense when you get to it... hope this helps.. good luck
platinum01
Willis, TX
I'll check it out tomorrow. I have a ranch hand bumper on the front so I'm sure that is going to give me some heart ache also. LOL
strokepower
Stroke=Power
Cook Station, Mo
yeah its possible.. i have found the screwdriver method to work the best... you only gotta bend the grill back about 3 inches..
platinum01
Willis, TX
Sure the guy that made that grill was laughing every second he was molding it. LOL LOL Now that I keep reading your post it sounds pretty simple.
strokepower
Stroke=Power
Cook Station, Mo
I know what ya mean... the first time i went to take it off my 05 after having my 03 i was feeling around on the bottom thinking "i know those clips are right here" then i had to look and saw how complicated they had become LOL
Romie64
