Question anyone use synthetic MTF rather than mercon in a ZF unit
I've been using Red-Line D-4, full Synthetic (ATF), in my manual trans's for Years.. and thier Synthetic rear dif lube too.
A bit pricey.. but good stuff.
You can check'm out @ redlineoils.com
dialedin86
dialedin86
Auburn, CA
thanks Joe, I have a case of torco full synthetic ATF and I will give it a try.
it says it exceeds mercon specs.
As long as it meats the Mercron V specs.. you should be.. Good To Go.
MJ Synthetics
So Calif
I can get you full synthetic ATF for less than the RL or Torco when you run out. PM me and get a quote its free! Lets see if I can save you money on the syn fluids you are buying now.
MJ
Romie64
