Help Needed four wheel drive not working
LAPLANT
Flowood MS
my 4x4 has not worked since i purchased the truck
I have checked all the fuses and relays and they are good
thought it was the GEM module so i replaced it with a new one from the dealership it made no difference
nothing at all happens when I turn the knob to any position no indicater lights come on or anything
hoping someone has some insight on this problem
thanks in advance for any help
LAPLANT
Flowood MS
Thanks for the reply but it is an electrical problem There is no power going to the switch or to the transfer case actuator motor:rant
Patrick Feeley
Tehachapi, CA
Is this on a 94-97 truck (sounds like you may be referring to a later model)? If not, you may get additional responses by posting in the appropriate forum. Cheers!
Romie64
