Pilot holes??
mp18d
Truckee, CA
So I'm building some gym type equipment, and have to drill a number of 5/8" holes in 11gauge mild steel rectangular tubing.
I don't remember from shop class if I should drill pilot holes to save wear n tear on drill bits and drill press, or just go to it with the 5/8 drill...:dunno :dunno
Does anyone else know??
Thanks!
Mike
ckamp52
ckamp52
italy,tx and stephenville
drill the pilot holes...reduces the bit walking on you for more precise holes and as you mentioned it will save you a lot of wear and tear on you bigger bit which costs more than the small bits you can use for the pilot holes i would go with about a 3/16 then move on up to the 5/8 and use some lube should be good to go
Or even a Step bit ?
If yer using a Drill Press, you could get'm done purdy quik. Makes a nice clean hole too.. :sweet
mp18d
Truckee, CA
Yeah, almost forgot about cutting oil...Musta cut class that day!:sly
Thanks for the help!
Mike
Ok on the prop wash, but I am having a hard time finding the Flight Line. Home Depot or Lowes?
Dave :D
It's right next to the Chow Line.. Dave.. at both stores. :sly;)
Romie64
