IDM Mod
early 99 stroker
White Mt's NH
there is a sticker on the IDM that will tell you..im 99.9% sure you the 120V..they put them in starting with the 99.5's..
Zookie400
I WANNA GO FAST
wallingford, CT
i have done this, you will notice power gains on a stock truck. if you already have a chip you are adding a nominal amount of power so the increase wont be felt.
early 99 stroker
White Mt's NH
not true....this mod opens the injector sooner..a chip can only controle the fuel use it gets..the chip or any chip cant controle when the injector opens and close...the IDM does that....this mod will give you a better low end grunt and a tad more fuel for your tunes to play with....it also helps spool the turbo a little faster...
Romie64
