no break lights ??
surreyboy
alberta canada
hey every one , i have a problem with my break lights , i have none . i checked the fuses & changed the bulbs , any one have any opinions as to what it might be ? truck is a 97 f250 . any help is greatly appreciated
thanx
do the turn signals work?
if so, brake lamp switch on the pedal
if not, turn signal switch.
94f450sd
certified nutjob
plymouth,ma
a problem ive run into with alot of fords with no brake lights is one of the wires to the brake light switch breaks off the connector.
exactly or a poorly installed alarm or remote start.
If your truck is an automatic then failure @ the brake switch may leave you stranded unable to get the truck out of park... guess how I know :rant
I'm guessing you have that t-shirt...
94f450sd
certified nutjob
plymouth,ma
had that happen on my old car carrier.stopped to count out enough change for a coffee.got my change ready and go to pull out and couldnt get the truck out of park.got pissed and wrenched the shifter,snapped the pin off the shift lock.found out i had no brake lights but my tranny shifted fine.spent the day lookin for broken wires cuz it kept poppin the fuse.had the dash apart,ripped open wire harnesses and found nothing wrong.decided to snipt the wires to my drag light plug and everything worked.got salty slushy water in the plug and shorted it out.man was i mad :rant
georgetown texas
I'm just wondering if the brake light is out also?
When my turn signal switch went out causing the brakes not to work the turn signals worked. The hazard lights was the gremlin when you turned on the hazard lights the right indicator on the dash wouldn't flash.
94f450sd
certified nutjob
plymouth,ma
a little money saving tip.if you do end up need the turn signal switch(multi-function switch) take it out and open it up.clean all contacts inside with some carb cleaner and lightly sand them or use steel wool or something.clean it again.dab some di-electric grease or a light wheel bearing grease on it and put it back together.same thing if you delay wipers aint workin,open it up and solder the broken wires back together.although the switch was only 40 bux last time i checked but no sense spending 40 bux when you can fix it for 5 or 10
surreyboy
alberta canada
could some one please point me in the right direction as to where the hazard & multi-functions switches are located & what i would be looking for in the terms of appearance ? thankx a million ppl !
F350 On Track
