Parts Interchange Guide (fact or myth?)
nswsparky
All my stuff
Grove City MN
Do you think the plastic curved light from the upper models fit my XL bare bones square 1 piece lights?
Bad Night
Uniontown Ohio
Yea . They will fit . I have a set you can have if you want to pay the shipping . They are stockers out of a 99 . I have a chrome grill too . Just pay shipping .
Here are the headlights and grill
By the way here it is now
eZAK61
Lombard, IL.
You may want to try you local bone yard!
The one here will look up your part and tell you what fits.
Stroked68
This is FORD Country
Eudora, KS
Alright I have been tryin to find info on tow mirror swaps. I have the non tow mirrors on my 99. I know that any of the tow mirrors will bolt up directly BUT, the wiring plug ins are different. Mine is a flat 4 plug in and the tow mirrors Im interested in are a round plug in. Any insight on this? I'd rather not do any splicing but I will if I have to. The tow mirrors i've looked at are power mirrors with no heat and manual telescoping. I can get them very very cheap. :sweet
eZAK61
Lombard, IL.
You can just change either plug end, round or flat, to match
Look online or at a bone yard for the one you want to change.
Swap it out (re-pin) and your done! No splicing!
*If the color code is different then you will have to use a meter and some jumpers.
Stroked68
Eudora, KS
Is there a special tool for unpinning my connectors? I do have one for lawn and garden connectors. Dont think it would work on my truck.
eZAK61
Lombard, IL.
Yes, They do make a tool to take the pins out of the connector.
You should be able to find it at an electronics type store (Radio Shack, Fry's, etc...)
OR
You can use a small, flat blade, screw driver.
Its tricky and you'll need some thing to hold the body.
Locate the locking tab, (either on the female pin or on the crimp itself)
Depress & pull wire at same time.
When re-installing pins make sure the locking tab is slightly bent out.
Stroked68
Eudora, KS
Kind of figured that. Thanks for the info! I might have to try that since Im gettin these mirrors dirt cheap. Or I can just cut the connectors off and just crimp on bullet style connectors. Only has like 3 or 4 wires.
