Question F250 needs new tires-opinions wanted
Deerjager
Meister Gewehr
Forest City, NC
I will need to buy some tires for my '01 F250. I use the truck for family trips and as my hunting vehicle. I spend time in the sand down near the outer banks and in the red clay med here in the foothills. I had good luck with mileage & traction with the Firestone SteelTex ATRs that came on the truck. I got 43K out of them and gave them to a friend who ran them for 3 years on his '88 K1500 GMC shortbox.
The truck currently has Uniroyal Laredos on it. Basically, these tires suck. I have had two of the original 4 have belt separations. I have one on the rear acting like it is going bad. These things do not have good traction in the red clay, becuase the tread does not clean well, but they do ok in the wet sand. I wish I had gotten an AT tread instead of the all season. Oh well, lesson learned. Will not buy Uniroyal tires again.
I have looked at the Terra Grapplers, Pirelli Scorpions and the BFG ATRs in the E load range. I am still running the factory aluminum wheels and the stock tire size of 265/75R16. Michelins do not have an aggressive enough tread design from what I have seen.
Any opinions on what I will be happy with? I prefer a tire with a white letter, so the Nittos have been moved to the bottom of the list for now. OWL is not a deal breaker. Tire noise is not an issue, since I no longer have the muffler :D.
E99F250SD
Jefferson, MD
I really like the BFG ATRs, in 285s they come in load range E, they do not rub with the stock wheels on my 99 250. The 295s do not come in Es, but the next size up does. I run the 285s on the 250 and 295s on the Ex, but had to get wheels with more back spacing and neg. offset to prevent rubbing on tight turns on the Ex.
on the bfg atr...you cant get the white lettering on the load range E. Only D has them. But other than that...I had 2 sets on my last truck and they were phenominal...great in the sand, good enough in the mud and quiet on the highway.
I had 35x12.5x16.5 BFG AT on my 04 and I'm going to get another set for my 08 truck. I loved them.
Stroked68
This is FORD Country
Eudora, KS
You can always get the tire pens to color your letters. Never used them but know they are out there.
Romie64
