Question Vacuum problem or A/C
Yukonsam
BC
Hi guys I am new here and kinda having the same issue. 2004 F350 6.0L My a/c is blowing cold and my clutch doesn't seem to be engaging at all. Starting to drive me nuts as its getting HOT. I cant seem to find this Grey hose that everyone keeps talking about. Wondering if you guys could point me in a direction for the a/c clutch.
jccapri
garland,tx
Turn your key on go under yhe hood on pass. Side undow a vac.line and the pump will come on look to the right of it and there is 2 vac. Lines going to a valve with wires un plug lines and plug them with something and see if your ac works thin
