Electric Brake Controls
mward3
OH
I have a 2006 F350 Super Duty 6.0L that I bought used. I use this as a daily driver and to tow a 13.5K RV. It had an electric brake controller already installed (hardwired in under dash). I want to replace this with a P2 Prodigy that came with a plug-n-play connection but I can't find the plug under the dash. Can anyone give me some guidance here.
Thanks,
Mike
kingkevindavid
Middleboro, Ma
it is tough to see but if you look up under the dash it is to the right of the fuel pedal. It is a ways up so you have to look hard. Took me a bit to find mine when I put it in. I also want to say that it is attached to a metal bracket.
I basically just looked for the only plug with nothing plugged into it.
rhensonsr
