Low fuel pressure
T VALK
PAINT BY VALK
PORTLAND CT
Just installed fuel pressure guage only have 25 PSI .Should I start shimming FPR or something else wrong?
Does it start & run okay ?
Where did you tap in to get the pressure reading ?
jtfarns
JTFARNS
palistow nh
I have one and it is tapped into the fuel bowl. I get about 62 psi with a stock fuel system.
T VALK
PAINT BY VALK
PORTLAND CT
Starts fine and runs okay idles little rough.Guage on rear of fuel filter housing.
Fuel Filter clean ?
If you just now hooked up the fuel gauge.. it may take awhile for the pressure reading to stabilize. Did you purge the line from the bowl to the gauge ?
T VALK
PAINT BY VALK
PORTLAND CT
Just changed fuel filter and took QD off fuel pump feed.Did not bleed.Went round block pressure still same.
Yul need to purge (bleed) the tubing line From the bowl, To the gauge.. at the gauge. Air in that line will not give you True fuel pressure. (air compresses differently than liquid ?)
Is the gauge in the Cab ? If so, you [should] use an [Isolator]...
On edit: Try driving it for a day or two after you bleed the gauge line.. you may have some air in the fuel system.. from the QD inlet delete ?
Romie64
