Important Information for 2013-2014 Superduty Owners
makuloco2000
USA
In this video I go over a rash of new all too common low mileage issues happening on the 6.7l 2013 and newer causing the trucks to shut down. This can ruin a family vacation or worse delay a delivery of what your hauling as I know allot of these trucks are used as cross country transports. I get more and more into details as I go on, it is just something owners need to be aware of.
http://www.youtube.com/watch?v=bXztq2pGTIM
THANKS !!! VERY good info to know !!!
Will/would using a fuel additive that bumps the #2 ULSC diesel Cetane level up (for a cleaner burn) help to keep this EPA driven crap from happening ??
makuloco2000
USA
Nope the Nox will always be there with the high temps in diesels.
Roger That.
How about more Intake air than the OEM intake~filter allows ?
I think I see where you are trying to go with this. NOx is a byproduct of combustion. A bigger Air Filter will not help Joe.
Dave :dunno
We'll now. Wouldn't that throw your hat in the creek.
Dave :dunno
:lmao
No..... I was just thinking more air, under load demands (towing/carrying= more heat) >might< make for a [better burn].. reducing NOx, and not tripping the D*&N limp/idle mode. makuloco is speaking to the 013/014's but... makes a 012 body wunder ?
My 012 hardly ever does a DPF burn since I did the aFe thing.. and run a good dose of PS in every tank.. :dunno
Jus' say'n
From what I heard Makuloco2000 say, your 2012 is good in this department. You should not have that problem with yours ;tu
Dave :)
Romie64
