Dies in reverse
jake19xx
il
My 99 7.3 dies when the truck has warmed up when i put it in reverse. If its cold it backs up fine. It is auto. I have a video if i can get it to post up
trackspeeder
Stone Crusher
North Branford CT
Torque converter is drifting. (Trying to lock the clutch). Check the fluid level. if it's low this will happen.
If the fluid level is good. Then you have an internal leak or pressure issue. The tranny will have to be pulled to repair the issue.
jake19xx
il
Fluid level looks good. Nothing else to to check then?
Do you have 1st gear? Its sounding like the clutch pack came a part. 1st and reverse are in the same clutch pack if I remember right. Don't try to drive it, you'll do more damage then you want to pay for.
jake19xx
il
It drives fine forward its just backing up that it does it
trackspeeder
Stone Crusher
North Branford CT
Third and reverse are shared (direct drum).
There is an internal leak in the tranny. What is happening when placed in reverse, fluid is leaking into the converter clutch circuit. When this happens the clutch will try to apply.
jake19xx
il
Well that sucks. Back to truck less for awhile sounds like
rhensonsr
