2017 F350 SRW rear axle
HorseShowDad
N. California
Does anyone have the specs (make and model) of the rear axle on the 17 F350 king ranch 4x LB SRW?
I think it's Sterling but not positive. It's definitely different from 16 and earlier models
HorseShowDad
N. California
There is a tag on the axle housing with a code number. That will tell you/us the axle.
Thanks. From my research that code just gave me The ratio but not the OEM specs. Specifically i had heard from a dubious dealer source that the axle was an 9000 lb axle that was de-rated to 7000 to match the 10 plyE tires
In the end it doesn't really matter but more for some piece of mind!
Thanks a bunch. If you still think that code will help I'll get. Just sick in bed today
