modifying 94-95 timing cover for 96-up HPOP
just figured i would give a quicky update to this and bring it back to the top so that the newbies can read it.its been a little over 7 months now since i have done this mod and no problems yet.fires right up every morning even after sitting for a week:sweet
:thumbs
Radarman
Beaverton, OR
Yep working great for me too. I have let the truck sit as long as a month and it starts up just great on the first turn of the key.
strokin'_tatsch
death row inmate #7
Austin, Texas
wow that sounds awesome. i will probably do that to mine too when i get ready to get an HPOP and injectors, haven't got to gettin' many mods though. i'm a little short on cash since i just got my tranny reworked and got a new clutch, pressure plate, and flywheel. right around $1200 right there. so it will be a while before i can do that
Powerstroke2000
British Columbia, Canada
Rich, am I reading this right...you went to all this trouble...then upgraded to a "Stealth" HPOP?
I'm still using my "Nit" accumulator with great results on my '02 HPOP, but realize it's not for everyone.
Any updates to the write up you did?
Thanks..
Powerstroke2000
I ain't no Stealth expert but I think the Stealth system uses your stock reservoir ? :dunno
94f450sd
certified nutjob
plymouth,ma
the stealth comes for either the 94-95 trucks or the 96-up trucks.when i bought my stealth i had a 97 engine in the truck.so i got the stealth for 96-up trucks.i have since blew my 97 engine and replaced it with a 95 engine,hence the reason i went through this trouble.i couldve simply swapped the timing cover but i figured there had to be an easy way to run the 96-up HPOPs on the 94-95 trucks.and guess what?i found a simple way to do it AND KEEP the factory look of the engine
94f450sd
certified nutjob
plymouth,ma
Im going to update this again and bring it back to the top since ive been seeing alot of psd noobs lately.
The truck has been sitting for a few years now and still no leak down.last time it ran was sometime last summer.I went to get it and bring it home again.took 2 tries and she fired right up.now we know that this works perfectly long term.
Jason haggerty
Richland wa
It seems like it’s been long time but I need some pics of this mod and how did it work long term thanks
79jasper
El Paso, TX
Why? All you have to do is tell your pump builder and they can make it work for any style cover.
F350 On Track
