troutwest66
6.0- The Dark Side!
Post Falls, Idaho
Had the tranny serviced in June and wouldn't you know it got a new oil cooler and the EGR cooler went missing?? Next to be put on is the Sinister Diesel Coolant Filter.
ampb5rider
US
Just getting to this. Yesterday I wire wheeled the drive shaft, cleaned it, and sprayed rust converter on it, two coats. Hit a few other areas also. Checked tire pressure, and increased the rear, based on the door tag, Wow 80psi rear, 65psi front. May have to relearn TPS!
01yellerCobra
Cali
Picked up a sun visor with the Homelink buttons. Went to install it and realized Ford glued the plug somewhere I can't reach through the hole. I need to drop that corner of the headliner to get it. I decided that was more than I wanted to deal with at that moment. So I while I was putting the old back in place I managed to drop a black screw into the abyss that is my black interior. Haven't seen it since. Guess I'm going by the dealer.
ampb5rider
US
Wire wheeled the front driveshaft, sprayed rust converter, then painted it, also did the control arms and front axle. Fluid filmed the bed wheel arches and bed support channels along with any hole under the truck I could find! Added The banks Data monster and ram air intake a couple weeks back.
bears4x4
grease monkey
katy texas
fluids and filter on excursion. Pulled replacement engine for swap out on f250. Good times a coming
shooterchief
Buras, La.
Added the topper. Carpeted bed to roof, 2 long LED strips and the lock is tied into the truck alarm/key fob.
Wow! It’s been 14 years since I last posted anything in this thread. Since I got my new to me 2005 F250 CCSB FX4, I have done the Hi Idle mod using the upfitter switches, Fog light mod, new window vent shades, new 3rd brake light with LED’s and new Ford Emblem on the front grill
