Smell of engine and dirt in cab
storms02
Idaho
I have a 05 F250 6.0l SD. I bought this truck used and I am having a problem with dirt, and engine smells coming in the cab. When I drive down dirt roads the glove box and cab fill with dirt and dust. While I am driving in town I can smell exhaust and smells coming in the vents. It also sounds like the passenger door is slightly open. Can anyone help me out. Thanks
01yellerCobra
Cali
Unfortunately this one is going to require you climbing around the truck and checking things. If the door seems slightly open you can adjust the latch so it closes properly. If you still have the dust and smell issue you're going to have to check the condition of the rubber plugs and seals and replace as needed.
storms02
Idaho
thanks for the info
Romie64
