Spice Up the Style of Your Truck with a New LED Tailgate Light Bar by Lumen + Video
Give your truck unique, eye-catching appearance while also improving functionality and driving safety by installing the new Universal LED Tailgate Light Bar by Lumen®. The accessory will surely attract the attention of other road users, especially with those 3-stage sequential ember turn signals and hazards. It comes in two lengths for mid-size and full-size pickup trucks to fit snugly into the recess between the tailgate and bumper. The accessory features 1000 and 1200 bright, energy-efficient and vibration-resistant LEDs for 48- and 60-inch variants respectively.
The installation process is very simple and doesn’t require any drilling. You just attach the bar using a strong 3M adhesive tape and plug in the connector into the 4-pin flat trailer wiring harness of your truck. You may need an adapter if your vehicle has a round 7-pin connector, or you can simply tap into your tail light wiring with a provided pigtail to ensure the operation of the bar’s running light, stop, turn and hazard signals, and the reverse light.
Lumen® - LED Tailgate Light Bar
Notes:
The bar is not compatible with Ford's Blind Spot Information System (BLIS) with Trailer Coverage and Cross Traffic Alert.
Specifications:
Number of LEDs: 48” light bar – 1000, 60” light bar - 1200
Housing material: aluminum
Can be cut: no
Plug: 4-pin flat connector
Warranty: 1 year
Features:
Dazzling LED Sequential Turn Signal Display
Super Bright Reverse Lights
Weatherproof construction for reliable operation (IP67 ingress protection rating)
Dependable operation in any weather conditions (Working temperature range: -20°F to 170°F)
Easy Plug-and-Play Installation
If you have any questions, feel free to ask them in replies or in private messages.
Also, you can contact our technical experts in Live Chat at CARiD.com or simply call 800-505-3274 (tall free).​
Today we are back with a new video, dedicated to its installation. Our tech expert Greg will guide you through each step, with all the tools needed and detailed explanation of the whole process. Finish off the look of your truck and make it safer with Lumen LED Tailgate Light Bar!
