When it comes to the performance of your truck, improving the air intake and exhaust system is always the right way to go. aFe offers some of the most advanced air intakes and exhausts for Ford. They will provide safe improvement in HP and torque without affecting the reliability of your engine. Each system is designed with the welded-on bayonet hangers that allow for the most secure installation possible.
Do not miss out on an amazing Memorial Day Sale at CARiD! Save big on aFe products, and shop with pleasure! For a limited time, enjoy savings of up to $790 on select aFe Power products! This sale ends on May 31, 2020. Prices are already reduced.
aFe® - Mach Force XP™ Exhaust Systems
Features:
- Up to 29% greater exhaust flow than stock system
- Increases horsepower and torque
- Improves performance
- Lowers exhaust gas temperature
- Flow bench and dyno tested
- Welded hangers with swaged ends
- Slotted and swedged ends
- Premium quality band clamps
- Backed by a 2-year limited warranty
- Proudly made in the USA
aFe® - Momentum™ GT Cold Air Intake System
Features:
- This system uses a high quality plastic CAD designed, dyno-tuned, roto-molded intake tube to achieve maximum power gains while maintaining a perfect fit. Also included is a high quality billet aluminum crankcase fitting provided for easy installation.
- A high quality CAD air scoop guides cool ambient air to the performance air filter.
- This Momentum GT intake system was designed around the largest filter possible to allow maximum performance and filtration. This cylindrical filter has a large oval (6-3/4" x 4-3/4") flange and is 9" tall inverted top Pro 5R filter media. The Pro 5R performance air filter features 5-layers of progressively finer mesh cotton gauze oiled media and is constructed with 100% polyurethane frame for long life and multiple cleaning cycles.
- Premium stainless steel clamps and a silicone coupling are used for strength and durability while also providing the most secure installation available. Momentum intakes are designed with fewer parts for a quick and simple installation.
