Question Anyone have ideas on why dash lights don’t go off with engine running . Just bought this at an auction. Runs real good. 2011 250 6.7 lariat xl. Thank
Check your PCM for error codes. Use a scanner to get the codes. This will tell you what the problem is. All WE can do is guess.
MilesHub
Walla Walla, WA
I checked and it was two codes both related to o2 sensor kinda thing. I’m just wondering has anyone heard of this or have any ideas? Thanks much
The O2 sensor code is common in these trucks. It is NOT telling the PCM if you have good fuel/air ratios. Do you see black smoke?
