02 f350 trans problems
mac07007
ontario
transmission seems to kick outta gear at idle. if u rev it up a bit it takes off and seems to shift fine until u stop again. im guessing tranny going for a crap?
mac07007
ontario
Have you checked the trannu fluid level?
Dave :dunno
yes its full and not burnt. seems to be fine except at stops and takeoff . maybe oil pump in tranny getting weak?slips until it hits 1500 rpm then then takes off
JRNOLL
Bakersfield, Calif.
It is acting like it has a high stall torque converter in it. I really don't know much about automatic transmissions , But you may be able to adjust the bands in the trans and have it work better. I hope that someone with more knowledge, will help you out.
mac07007
ontario
Thats exactly how it was taking off. However i dropped the pan to find a pile of ground metal that would prob fit pepsi can. Put new filter on replaced fluid and now it does nothing. Weird but it has over 400000 on it so i guess its time
If it's only got just over 400000, yep it's time for a good rebuilt one.
Joe, his 400000 may be KM's so that would still be about 248548. It's for sure time for a new or rebuilt one.
Whoops.. didn't check the Canada location. Still probably time for a Tranny.
