03 w/CCV?
mp18d
Truckee, CA
What year did they stop putting the CCV on the 7.3?
I just put an AFE Stage 2 system on it and there was no connection tween the intake tube and the driver side valve cover. Yet there is a sheen of oil on the valve cover and at all the turbo tubing joints...
Still trying to track down a new oil leak at the rear of the engine....Little puddle in the forward valley, little puddle occasionally under the truck. Oil galley plugs all ok...
Any other ideas? :dunno
Thanks
Mike
It is still there, but I can't tell you where, because I don't have a 7.3. Someone will jump in here to tell you...
dpantazis
#12
under the cheddar curtain
look at the top of the drivers side valve cover, on the top of the cover.
there is a 90 rubber hose from there to the backside of the plastic collar that is bolted to the bracket.
oil leaks- wash down the motor and start looking. could be seeping at the turbo, turbo pedastal o rings, weeping HPOP, oil gallery plugs on the heads, sloppy filling.
mp18d
Truckee, CA
Yup, I found the dumb thing. It is really buried! Now to do the mod, it is making a mess and hard to clean around unless ya take the whole induction tube apart!
Thanks for the help!
Mike:)
