04 vs 05 and difference between lariat and XLT
bradyhoward
Portsmouth/VA
Hi, all, I'm new here, I've owned 3 diesels, and want another one. I will be lifting it enough for 35"s I am looking for opinions on 04 to 05, I like how quiet they are and the power. I am also looking at an XLT, it has leather but it's buckets in the front and I want the 40/20/40 bench. I'm financially limited otherwise these wouldn't be issues. Thanks Brady
groundhawg
Indiana
The '04 was the last year for leaf springs in the front, the '05 up are radius arm/coil springs. I personally think that the 05 up ride a little better, it's a little smoother going down the road anyway, but it isn't that much of a difference.
Not sure what the cost would be to get 35s under either one though, mine is still stock height and 33s should fit without issue. I think that coil spring spacers and F350 blocks out back would most likely clear 35s on the 05 and up F250s and spacers alone on the F350s.
I'm fairly sure that the leather seats were Lariat only issue, unless someone either swapped them in or put aftermarket leather covers on the seats. Either way, I doubt that you would have too hard of a time finding someone who would trade with you.
Another option, and I forget now who did it, but there is a write up here on this board where a guy had factory captians w/ console, removed the console and the arm rests and then installed the "40" part...just have to do a little hunting for the artical.
As far as power, I'm happy with my 6.0L. Add a few upgrades to it and it will really scoot. They aren't really any louder than the 7.3s I don't think...but the Duramax trucks I've been around are super quiet. I've got a 4" MBRP on mine and it is a little louder, but not much until you open the throttle...and even then it's not stupid.
Bill Rudell
Lake Isabella,Ca.
Good question. This is my 2nd ford deisel (04 f250 SD 4x4 extend cab long bed) and with a little help from Hypertec and a Stage III in the computer it halls my 3600rl raptor with no problem. 11/12 mpg on the last trip to northern california. empty i get between 17 and 20. But i have found out the ford says the o4 is rated at about 12000lb.towing a 5th.and the 05 at 15600, but according to the ford service manager at home the trucks have the same parts. Go figure.
Does anyone know why?
