1999 7.3 Superduty Leak at Differential
BILLANDSYL2
Ayden, North Carolina
My 1999 7.3 Superduty has an obvious leak at the rear end of the driveshaft. It looks like it is coming from the seal at the differential. The leak may have spread to the Speed Sensor since the result is no speedometer, ABS light stays on and cruise control will not work. The overdrive light on the shift knob also blinks on and off. Does anyone knot the seal part number for this differential and the cost and where to buy. What is involved to replace this seal?
Thanks,
Bill
fordtrucker4life!
I work with waste
SE Michigan
Welcome to the site. You can buy the seal at any parts store in your area. I don't know the part number, but if you give the parts store all your info they will be able to find it in thier system.
