1999 7.3L PSD cranks, no start, intermittent start
Vonnie
My Hubby's 1999 F350 7.3L PSD was having an intermittent starting problem that is no longer intermittent. Cranks strong but will not catch, when I could get it started it ran great. No smoke/fumes from exhaust while cranking so I'm thinking it is not getting fuel rather than a glo plug issue. Fuel pump is working, filter is new/clean and bowl is filling. Also good quality/quantity of oil including in the high pressure reservoir (you will have to excuse me if I call parts by the wrong name). I replaced the cam sensor thinking that may be the issue but no luck. I would be thankful for any help you could offer as I am pretty clueless.
Hi Vonnie, and Welcome to Super Duty Diesel. Does it start normally if it is warmed up? If so, you may have a glow plug problem or a wiring harness under the valve covers. The wires run under the valve covers to the glow plugs and may now be connecting correctly. Good Luck.
Dave :)
Vonnie
Back when it would start part of the time it did not seem effected by engine or ambient temperature.
Vonnie
Thanks guys for the advice and the quick responses! I love this site. Well, I went out this morning and the beast fired right up. Either I am back to an intermittent problem or the crank sensor was the cause but took some serious crank time to kick in. I guess I need to get out of the 911 section, anyone know how to do that.
One last question. Is there any way to reset the PCM manually or do I need access to a scanner.
To reset the PCM all you have to do is disconnect the POSITIVE battery cables, leave them off for a few minutes and then reconnect them. This will reset all of the features in the truck like the radio stations, so be forewarned.
Vonnie
Ha! Well, that could have been what solved my problem. I had pos cables off to charge batteries after all that cranking.
