2-stroke oil
dsonyay
Slidell, LA
Is anyone mixing the Marine 2Stroke oil in their 6.4? I read about it all the time but not sure if it's OK to use in the newer engine. Sounds like something the 6.4 would agree with. I'd add it along with the Cetane booster I use from Ford too.
My take on it is.. the 6.4 parts, pieces, seals & gaskets are designed, from the gound up.. for the ULSC diesel. No additives are needed to compensate for the limited lubrisity of ULSC.... like with the older engines.
But.. I wouldn't think it would hurt anything :dunno
dsonyay
Slidell, LA
that's true. I didn't think of that.
Zookie400
I WANNA GO FAST
wallingford, CT
this is just a speculation, but i would think it would clog the dpf more often and go through regen more. other than that i dont see how anything else would be harmed, but like joe said, it was designed with ULSD in mind.
Good point Zookie, about the dpf. Something ELSE to think about.. before using a fuel additive in a 6.4 ?.. the dpf.
