2 Trucks Different Results
thelastcion
Magnolia, TX
My father and I both on 07 Harley Davidsons. His is an F350 and mine is an F250.
We both use the Bully Dog Triple Dog. We use all 3 settings depending on the work load.
I can get upwards of 22 MPG at 75 mph and he can't get above 16? Does this simply speak to the fact that no 2 engines are the same? Or is there something that can be done for my fathers truck.
No other mods have been made to either truck, performance wise...
keanoknick
Big Stroker
Cowtown TEXAS
What gear ratio's do you have, I'd bet you have 3.73's and he has 4.10's which would explain the difference.
climb under those beast and look at the tag...easier still theres
a tag on the door too !
there will be an AX code on the door sticker...mine is D1 & is a 3L73
this is not a comprehensive list...
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 — 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 — 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 — 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 — 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 — 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 — 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 — 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
F2 — 4.10 limited slip, F-350, dual rear wheels
88 — 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW — 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 — 4.30 limited slip, F-450 Chassis Cab
73 — 4.30 non-limited slip, F-450 Chassis Cab
78 — 4.88 non-limited slip, F-450 Chassis Cab
G8 — 4.88 limited slip, F-450 Chassis Cab
75 — 5.38 non-limited slip, F-450 Chassis Cab
G5 — 5.38 limited slip, F-450 Chassis Cab
GW — 4.10 limited slip, F-450 Chassis Cab
98 — 4.88 non-limited slip, F-550 Chassis Cab
K8 — 4.88 limited slip, F-550 Chassis Cab
95 — 5.38 non-limited slip, F-550 Chassis Cab
K5 — 5.38 limited slip, F-550 Chassis Cab
KW — 4.10 limited slip, F-550 Chassis Cab
woofer700
Diesel is cool
S/D
holy buckets Bush, i hope thats cut and paste, or do you really have all that in your head
hey people ask...i help (where i can).... or cut & pasted...
some of us 'round here are pretty handy w/ wrenches AND
a "mouse"
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
I would think the flash stategy is different between the F-350 and F-250. I'm not happy with my truck getting 15 or 16mpg ether.
