2000 PSD 7.3 Failed cont. test and buzz test
Bad Night
Uniontown Ohio
Ok so a friends 2000 7.3 started running and idling rough and has lost power . He already had the valve cover gaskets replaced (last week after this first started) I scanned it and did a buzz test and contribution test . It failed both . The buzz test I could hear a huge difference when it hit cyl. # 5 . Very quiet buzz . Contribution test also # 5 shows bad . Does this mean that injector is just bad ? Is there more to it ?
yeah, clip the injector harnesses together in the UVCH, if it still fails, it probably needs an injector
Bad Night
Uniontown Ohio
I found it tonight . The wiring harness was shorting out on the shock mount and killing # 5 injector . 2nd wiring harness issue in the last couple weeks .
fordfury
redneck punk
idaho
thats kind of funny i just fixed one it was killing number 5 injector too but it was rubbing on valve cover and grounding out. fixed it and new idm later and runs good
Romie64
