Help Needed 2001 transmission problems
dhenry
texas
2001 7.3 with 100k
The problem started with an intermitting shift problem from 2nd to 3rd sometimes requiring me to slow down or come to a complete stop. at this time the code read 732 (2nd to 3rd ratio) and 470(EBPS) also about this time it started taking longer to start. Now 2000mls later it will not shift up out of 2nd gear. when it reaches speed to shift up it acts as if an engine brake is applied. it then must be slowed to 1st gear or to a stop.
the EBPS was replaced and tube cleaned. the codes were then cleared and test run showed no change other than the only code showing now is 782(also 2nd to 3rd ratio)
Any help please!
Thanks D.Henry
hello, AAMCO??? your trans is borked...
sorry, Dude...
it's trying to apply two gears at once, probably because of an internal hydraulic leak, ie. worn or cut seal...
well, yes and no..
BTS builds the toughest unit you can get, but he may (like I) not have five large to drop on a transmission...
dhenry
texas
Why would a bad transmission make it more difficult to start?
