Driving along no issues, truck just died. Cranks no start. No Codes on edge tuner(stock mode, bought for guage pack) When cranking no RPM on dash. No smoke, FICM, TURBO, EGR, EGR cooler recently replaced Need help!! I don't have a scanner,
Crank position sensor?? Dont know alot about the 6.0's. I know on the 7.3's if that cps goes out yer dead! And all it is is a lil sensor.
There are several sensors that can kill a 6.0 if they fail. The 6.0 is NOT known for faulty CPS. More likely your HPOP is almost gone. If you don't get 500 pounds oil pressure, it will not fire the injectors. You NEED a scanner to find out, OR take it to a GOOD garage and have them scan it. Must be able to read CAN to scan a 6.0. Dave
I have had this happen twice. First time it was the injection control pressure (icp) sensor and the second it was the fuel injector control module (ficm). They both cost about the same, $1200 or so. Both happened away from home so I had to let someone else work on it. The icm had more parts, less labor. icp sensor had more labor, less parts. Since you just changed your ficm I would hope that is not it. You wont get codes on your edge but the shop will be able to diagnose in seconds with their reader. $120 diagnosis charge is well worth it at a good shop. 6.0 parts are way too expensive to throw them at a problem!
Mine was the IPR (Injector Pressure Regulator), It's what regulates the High pressure oil, HPOP (high pressure oil pump) just moves fluid. If it fails open you'll never get the 500psi required for the ficm to fire the injectors.
