2004 F350 low power/stalling
04Powerstroke
Ft. McMurray, Alberta Canada
Working on my friends F350, he says it loses power and sometimes stalls. He was talking to a friend that is a ford tech and he says it's the fuel pump. Where do I check the fuel pressure on the 6.0? Stupid question here, but, how many pumps are there? I know the one on the frame with the filter, but is there another?
Thanks.
theres a port up by the engine mounted fuel filter....
whats the conditions of BOTH fuel filters ? has the
HMFC been drained lately ?
any smoking ? or surging ??
check for wiring harness issues (03 & early 04s) had
wire chafing/ground out issues that caused stalling...
FDDTS - Recall in Review - Safety Recall 05S34
start the truck and w/ a WOODEN STICK/DOWEL start poking at all the
wiring connections and looms under the hood.
look these photos over for some of the harness/connector issues
Ford Doctors Diesel Technician Society
FDDTS - 6.0L Injector Harness
i assume the water in fuel light isnt on...givin that youre in a cold
climate you could have some wax build up...there were some early
problems w/ frame rail mounted HFCM..but most of those were
from wif lights that wouldnt go out AFTER they were drained.
the HFCM has a heater in it (brown plug on the unit)...if your
friend hasnt been keeping after it wax can build up beyond what
the heater can resolve.
FDDTS - Fuel Tank Contamination
FDDTS - A Word About Filters
classic fuel gel or icing symptom...
i had an old audi 5000SD freeze while "IN FLIGHT"...
dump some anti-gel in that tank or you could
end up stranded <w/out engine heat> !
