2023 & Newer Super Duty 30 minute Idle Shutdown – Problem Solved!
Merlins
Corvallis, OR.
You know that pesky issue that on the newer Super Duty’s (2023 and newer) where it will only Idle for 30 minutes then shut off?
And you can’t program it out in Forscan and the dealer can’t/won’t fix it?
Well, we figured it out and are offering the Idle On, that plugs into the factory harness and bypasses the shutdown all together, so your pickup will shut down when you turn the key off, and not before.
We also offer a unit (Idle On PLUS) that has the same bypass as the standard unit but adds the high idle feature if you want that too.
Why might you want this? well, anyone who needs their vehicle to stay running to power lights, testing equipment, heating/cooling, etc. law enforcement, ambulances, fire, utility workers, roadside inspection, K9 units, communications equipment and the list goes on of industries that need to run their vehicle longer than 30 minutes.
We just recently released our newest version of the unit that is now smaller than the original and uses surface mount technology (SMT) components, which make the whole unit smaller, improved reliability and performance.
You can check them out and read more about these if you are interested here merlinsfab.com
(This is a repost as my original posts got deleted by accident)
With the cold weather here, this unit works great to keep your rig running all day... shut it off when you want, not in 30min like Ford wants.
TEly
Back
