5R100 into 7.3 truck?
Powerstrokebloke
Brisbane Australia
Hi guys, over here in australia there is stuff all in the way of knowledge on these trucks, and after Ford trying to sting me near $700 bucks for a CPS, everythings bloody overpriced too.
I have a mate that has a 5R100 from a 06 F250 with the following part numbers
RF-6C3P-7006-BA 06 on body of box
RF-3C3P-7A040-HE tail casing
I have my transfer case from the 4R100....
I just ask, will the conversion be possible, and what else would I need if so?
I just thought for the money he is asking, its probably not a bad thing to leave under the bench till I need it.
I don't KNOW if it will bolt up to the transfer case. The motor is OK. Better if you can find the transfer case for the tranny, but that is more $$$. Good Luck.
Fire1
Certified Diesel Driver
If you are asking if you can mate the 5r110 to a 7.3, then NO not realistically. Sure anything is possible, but the simple answer is no.
92F350CC
Utah
Even IF you manage to get it to bolt to the motor, getting a computer to control it is a whole nother gigantic and expensive problem. Your money would be better spent building up that 4R100.
BTW, the Torqshift is called the 5r110, not 5r100
dserge66
