6 speed swap
Sport250
Down South, Texas
Hey guys what would i need to do a ZF six speed 4wd swap on my 95. As on now i have a ZF 5 speed 2wd with a divorced 205. Any info appreciated
well you're a bit better off than most in that you'll be able to use your existing transfer case unless you want to shift to the married variety
you're going to be essentially swapping out the transmission you will run into some cross member problems and the ZF6 does run cooling lines for an external cooler, If memory serves me right you'll also need to use the slave for the 6 speed, other than that I think you'll be golden.
