7.3L IPR
Ham Bone
I was reading in the infamous 7.3L CPS thread about the IPR or injection pressure regulator. My repair manual does not list this but then it doesn't list a lot of things. Where exactly is the IPR located? Is it what my book calls the fuel pressure regulator located under the fuel bowl?:eek:
Here's a Useful LINK that may be of help also:sweet
You'll need a 3/4 wrench to remove the jamb nut on the ipr sensor, remove the spacer and sensor. You then need a 1-1/8 deep socket and possibly a flex head ratchet to get the valve out.
If you're going to replace the IPR valve you'll want this IPR Valve Reseal Kit from Garrett.:sweet
