96 timing cover.....
geonc
my other 4X4
NECKVILLE NC
I need one and ather than puking up $500 for one at the stealership......????
I have searched all the sites from the search engine but all they offer is either whole engines or hot rod stuffs....no seperate regular parts.....
I have even called Bean, Swamp and all they have is customer engines.
There has to be used timing covers available:dunno
anybody...-popcorn
94f450sd
certified nutjob
plymouth,ma
well i have one.i really didnt want to give it up due to the fact that it goes to my other engine.but i will give it up to you if you want it.i just gotta find or make a puller to get the bottom pully off.all the pullers i have arent big enough to reach all 3 bolts.where did you get yours?
geonc
my other 4X4
NECKVILLE NC
What year is your cover?
I made mine from some plate and a straight puller bar that went between the plate and pulley.....
Laid out the radius from center -2 5/16" if not mistaken- spun circumfrence with compass then measured pulley hole spacing and drill out for 3/8" bolts with a 3/4 hole in the center...
May be crude butit was the closest thing available
Need to clean it up a little.....
pics.....
94f450sd
certified nutjob
plymouth,ma
its a 97 engine wich is the reason i didnt want to get up off it but you need it and i have it.
