97 f-250 down!
Strokin05
IL
my buddy has a 97 F-250 7.3.. here are a few problems..
1-no wait to start light....glow plug relay is not making any noise..
2-when you turn the key to start the truck nothing happens..if i jump the starter solenoid the starter just clicks once and then nothing..it is probably something simple..but i do not know where to start...please help!
does anyone have wiring diagrams for these 2 itmes....Thank you,
Mike
Tbar
SDD STAFF/Moderator
Batteries.....................get them load tested and if one is bad change them both.
Weak batteries cause all kinds of odd electrical problems.
Try jump starting it to get him out of a bind tonight.
Tbar
BBBxcursion
IL
Sounds like classic battery symptoms. It's getting cold out, get the batteries tested.
JOAT
I Found Nemo!
The West Coast
I'll agree, base on the limited evidence presented. Bad or corroded battery cables or connections are a possibility too.
Strokin05
IL
Jump start did not work!...on a volt meter each battery has 12.5 volts...when he turns the key the battery went down to 12.2 volts..Should they have more volts???..this has stumped me!..
Thank you,
Mike
Big K
SDD.com Hacker/Admin
Dallas, Texas
Jump start WON'T work if the batteries have DEAD CELLS in them.
Believe me, I have had this happen before.
It wouldn't jump with 2 set of jumper cables hooked to it.
2 New Batts, and it fired right up :D
Strokin05
IL
so even with the voltage rating they have we should stil ltry new batteries??? I hope thats it..
Big K
Dallas, Texas
OH YES,
I would have VOLTS from them, but not enuff AMP's in them to do anything thing.
Get the Batts tested, Any place can do this and you will know.
I am sure it is probably dead cells in them.
If you JUMP the starter solenoid, it should try to turn over if you are getting power to the starter, no matter if the truck has the key in it or not, that is what the solenoid does, connects power from the BATTS to the Starter, by the KEY in the truck.
It might be gone also though. I know mine just went out and have to start the truck by puttting the KEY ON and jump the solenoid till the truck starts.
GPR might be bad also, they go bad too.
I believe both are the same part, about $20 each at parts stores.
Let us know ;)
Strokin05
IL
thank you for the info....I appreciate it and i will let you guys know tonight how it works out..
Mike
Strokin05
IL
well fellas I appreciate the help, the truck is running...But now it wont shift out of park...
We repalced the batteries, the starter, and maxi fuse #22.....Thank you for your help...any suggestions on the the shifting aspect??
