A/C problem
02Oilburner
SDD Power Hungry
Raleigh, NC
My A/C is giving me some problems. It is 88 degrees today and the pollen is so thick it looks like yellow fog!! No A/C means riding with the windows down and pollen everywhere. The plug that is on the compressor makes the compressor engage and disengage when it is wiggled. The A/C works great when you hold the plug! How can I fix the plug on the compressor? thanks for your help!
IHC Power
STOCK STROKE
Walpole Mass
A/C Switch
If the terminals are spread apart on the compressor then just bend them back, if they are on the connector then just removed them from the body and mold them back into shape, good to go.
high resistance, heat and vibration will vibrate them open.. take a pocket screwdriver or something and bend them back over and it'll work fine..
in extreme cases you could replace the pigtail.
