A little help please.
StrokerAce7.3
ResidentBadAss
In a van, down by the river.
I need to install new Injector O-Rings and a Cam positioning sensor. I am an Auto Tech. but have never worked on a 7.3 so can anybody tell me the easiest way to do this, I need to knock both out in a weekend.
Tx_Atty
Master Baiter
Fishin'
click here for cps.
THe article on the injectors isnt up yet but there was a thread here somewhere about orings. pictures were included.
Here is an extemely detailed article on a 7.3L injector teardown which you dont need for the O-rings. CLICK.
And here is an article on getting them out of the engine. CLICK.
You can do the injectors in an easy day if you have average capabilities, the CPS is a 10 minute job. Good luck and ask if you have anymore questions.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I described how I went about removing and replacing my injectors in this PREVIOUS POST. Doing O-rings instead of injectors, isn't that much different except you're just putting the old injectors back in. The only thing I can add to what I desciribe in my previous post is to make sure you slob the injectors up real good with oil or STP when putting them back in. I used a big rubber mallet to tap the injectors in until they were seated.
or you could to like Budro did and press them in with the jack...
Tbar
SDD STAFF/Moderator
And if the above links are not detailed enough here are a few more pics that show the injector removal glow plug install and oring install on Chpmustang and Scarlet Napes trucks.
Pics
Tbar
