Added another gauge...
CSIPSD
Bend, OR
:roflmao ... Soon more... Intake air temp, pre IC and post IC...:burnit
The first step is admitting you have a problem...:thumbs
Tbar
SDD STAFF/Moderator
Dude, I don't think a 12 steep program is going to help you. :dunno
Tbar
bartman
Dallas, TX
Yeah, I'm thinking you should've done the 4-gauge A-pillar and you still have space to add a steering column pod as well....
CSIPSD
Bend, OR
Quad pod is sitting in the shop awating some prototype gauges from Isspro! Then I will add the under dash pod. I might do the steering pod if I find a banks six gun cheap...:thumbs
Thanks!!!:thanks
Gauges are pyro (soon to be two, right and left) boost, tranny on the A piller. Fuel pressure, oil pressure, oil temp, water temp in the overhead. The dash pod is Volts, Fuel level (big tank-100 gal), Manifold pressure, Drive oil pressure (for tranny pressures)...
architect-builder
Jerome, Idaho
1st of all;
Who told you P.M.S. was a problem?
Next, you need to change out the steering wheel with a stick, then the accellerator with a throttle control on the door panel. :roflmao
Pretty cool! :sweet
Barrett
bartman
Dallas, TX
Thanks!!!:thanks
Big props! I bet you glow blue at night :D while you're driving.
