Adjustable Pedals
Shawnrans
Placerville, CA
Are you able to fit the adjustable pedals in a truck that did not
come with them from the factory? My '02 has the little cut out
where the switch would go. Wondering about wiring, pedal assy.
etc.:thanks
HTRDDSL
HTRDDSL
St. Albert, Alberta
I have the 02 with that option. I'd be willing to bet you could bolt it right up. Ford has a habit of having the holes drilled for the extra pieces cause it's easier. I think the only work you'll have is the wiring and I think that would be fairly easy. If mine didn't have it I would have installed it regardless. My wife loves it cause she shorter than me.:)
yamahonda41
Seminole, FL
Hi,
I have a 2006 F250 Lariat FX4. Got it home to find out it did not have the adjustable pedals. My '03 F150 XLT had them for crying out loud.
I was installing my Pioneer head unit the other day and noticed the wiring for the pedals was attached to the back of the blank or dummy switch. Not sure if your truck has this wire but if so would definitely make it easier.
Probably just bolt it on and plug in a connector.
Let me know. I would like to add the adjustable pedal option to mine if possible.
