air lift
massie
kentucky
Question...... I have a 99.5 350 nose down... I like The idea of being able to adjust the height of the front to be level when hooked or unhooked to goose necks enclosed trailers etc. Will a front air bag give me this ability? How many inches will they raise? should not need more than 2.5.. How often do you have to add hour if you have a manual system without the built in pump.Thanks for your answer............sorry SP
odie43
Odie1450
Adkins,TX
I have the front bags on my 03 F350 CC 4x4, it raises up to 3 inches, I don't have the compressor system, I fill the bags to about 70 PSI and check once a month, usaully don't need any servicing. I did for the same reason you want to ...RV. It looks great and level either loaded or unloaded.
