Help Needed Alternator acting funny
Go with the ford part or see if there is a shop that will rebuild the original one for you. It'll most likely need a new voltage regulator and brushes. If it only needs one or the other go ahead and do both since they are the parts that typically have a limited lifespan.
Friis
Herning, Denmark
Hi all.
Thanks for the advice.
The problem is now solved thanks to a new original Ford alternator. The PSD is running great and I´m happy again! :D
